1.9TDI 74KW
- Car Model: Jetta 1.4TSI
1.9TDI 74KW
Hi Guys
Im new to the forum and would just like some advice.
Im in the process of purchasing a 08 Polo 1.9TDI 74KW the car has about 140k Km on the clock and has full service history until 130k odd Km.
How is reliability on these cars? and is there anything i should check for before buying the vehicle?
- Carel040
Re: 1.9TDI 74KW
Go for it very reliable and cheap to maintain , listen for the clutch thou rattle sound and turbo
Cheers
Cheers
- Car Model: Sportline
- Membership No: 3194
Re: 1.9TDI 74KW
Turbo, clutch, injectors. They are damn reliable.
Re: 1.9TDI 74KW
thanks so much.
looking forward to the new purchase.
- Carel040
Re: 1.9TDI 74KW
First thing to do after purchase remove Dpf and backbox , then software upgrade if clutch is ok then the fun will start
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Re: 1.9TDI 74KW
He won't find a DPF....Carel040 wrote:First thing to do after purchase remove Dpf and backbox , then software upgrade if clutch is ok then the fun will start
- Carel040
Re: 1.9TDI 74KW
Why
- Carel040
Re: 1.9TDI 74KW
O ok maybe because the rest knows it as a cat I suppose (DPF)
- Neuk
- Treasurer
- Membership No: 806
Re: 1.9TDI 74KW
No, because it is a CAT, it is not a DPF.Carel040 wrote:O ok maybe because the rest knows it as a cat I suppose (DPF)
- Membership No: 2033
Re: 1.9TDI 74KW
Great.......VGTI has 350k km's on his, my brother spdgti has 300k km on his CrossPolo. Regular servicing, decent oil and so on.NabbyM32 wrote:How is reliability on these cars?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Neuk
- Treasurer
Re: 1.9TDI 74KW
PD100 (OP) differs from the PD130 (VGTI).Howie-WP wrote:Great.......VGTI has 350k km's on his, my brother spdgti has 300k km on his CrossPolo. Regular servicing, decent oil and so on.NabbyM32 wrote:How is reliability on these cars?
Re: 1.9TDI 74KW
Thought his was PD100 as well however, being PD130 is even more impressive, then.......Neuk wrote: the PD130 (VGTI).
HOWIE-WP,
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Re: 1.9TDI 74KW
They are reliable cars and they respond well to mods.
Stock they also reliable VGTI one is a proper virgin, it still has the CAT in and still running on stock clutch.
Pure Epicness.
Pure Epicness.
- Neuk
- Treasurer
Re: 1.9TDI 74KW
Yep, the PD130's had the turbo issues, which amazingly VWSA issued a recall to address.Howie-WP wrote:Thought his was PD100 as well however, being PD130 is even more impressive, then.......Neuk wrote: the PD130 (VGTI).
Re: 1.9TDI 74KW
She is currently sitting on 342600 odd km, not quite 350k yet but getting there fast.Neuk wrote:Yep, the PD130's had the turbo issues, which amazingly VWSA issued a recall to address.Howie-WP wrote:Thought his was PD100 as well however, being PD130 is even more impressive, then.......Neuk wrote: the PD130 (VGTI).
Amazingly as you put it, mine wasn't part of the recall... perhaps, because it was fitted with a proper turbo?
Anyway, as Unobeat has pointed out, she is still on the first clutch and turbo. Oh and the front shocks... they are also still the originals
Only few tiny issues included a new alternator pulley one way clutch thingy and a filthy leaking intercooler.
- 4ePikanini
- Car Model: Touareg R5
Re: 1.9TDI 74KW
mileage seems low for a 2008.
Cluster could be swapped. Scan the ECU to check if ECU mileage corresponds to the clocks.
https://www.youtube.com/watch?v=LiGTYSh7GYQ
Re: 1.9TDI 74KW
Am new here and I have been driving a polo 1,9 TDI sport lite 6 push and had no broblem but now it's stated giving me problem like it starts on it's own then stops I noticed one fuse had Brocken and replace it it's start now but then sometimes stops while am driving and wen I accelerate it's reduce speed and stop the engine
Re: 1.9TDI 74KW
Cluster doesnt need to have been swopped for mileage to be rolled.4ePikanini wrote:mileage seems low for a 2008.
The guy who bought my 9n3 gti just plugged in a blue device into the obd2 rolled the mileage from 220k to 80k both on ecu and cluster . vcds picks up both ecu and cluster mileage as 80k. I was shocked! Apparently he did it cause his work pays for maintenance and it must be under s certain mileage... be aware....
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
- Carel040
Re: 1.9TDI 74KW
Ronaldo get your car scanned with VCDS then u will know what the problem is bud
- Neuk
- Treasurer
Re: 1.9TDI 74KW
I am still amazed that you are on the original turbo and clutch, proves that if a car is treated well it will last.VGTI wrote:She is currently sitting on 342600 odd km, not quite 350k yet but getting there fast.Neuk wrote:Yep, the PD130's had the turbo issues, which amazingly VWSA issued a recall to address.Howie-WP wrote:Thought his was PD100 as well however, being PD130 is even more impressive, then.......Neuk wrote: the PD130 (VGTI).
- Car Model: 1.9 Tdi Sportline
Re: 1.9TDI 74KW
Phone vw and check for the service history on the car...check if that is the true mileage...a lot of people getting their mileage chopped
Re: 1.9TDI 74KW
The clutch's condition is probably better than most 1 year old Vivos... the bodywork tooNeuk wrote:
- Neuk
- Treasurer
Re: 1.9TDI 74KW
The way that I have seen most people drive, I am not surprised, riding their clutch at traffic lights and then complaining that clutches never lastVGTI wrote:The clutch's condition is probably better than most 1 year old Vivos... the bodywork tooNeuk wrote:
- Unobeat
Re: 1.9TDI 74KW
Jueshen wrote:Cluster doesnt need to have been swopped for mileage to be rolled.4ePikanini wrote:mileage seems low for a 2008.
- Unobeat
Re: 1.9TDI 74KW
VGTI
Your car never ceases to amaze me at the way it performs and continues doing its duties.
The fuel consumption is something else, Pure Epic. A car like that would be hard to to find a replacement for hence you will just have to drive it until the doors come out on its own.
On average monthly how many kilos you putting on?
