2003 caravelle t4 2.5tdi
I've been trying to source this motor and gearbox but nobody has it. Can u advise a suitable diesel conversion? I was thinking 1.9 TDI maybe? Also cost involved and where I can fit it? Thanks
Re: 2003 caravelle t4 2.5tdi
That will be anhuge undertaking and making the management systems talk to each other again will be massively challenging. I Suggest you keep looking for the right motor.
- Membership No: 3103
Have you tried Matadoor Salvage and boss auto spares for the replacement engine? Whats your engine code?Rashied 1974 wrote:I've been trying to source this motor and gearbox but nobody has it. Can u advise a suitable diesel conversion? I was thinking 1.9 TDI maybe? Also cost involved and where I can fit it? Thanks
'09 8P S3 Sportback (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
Did you buy the vehicle without an engine or did it fail?
- amstel18
- Car Model: Tiguan Allspace
That's the same R5 motor as found in the Toureg right? Check out the thread on the 4x4 community forum. Theres a very well documented rebuild thread on there.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Not rebuilt. Remove and fit another. And the two platforms are extremly different although the base motor is the same.
But changing to amdiferent engine with a different cylinder count is extremly hard these days. There are several other controllers that wants to talk to the engine module and they use canbus and are all coded to each other. Unless you have massive knowledge and a huge amount of money and time it is a huge undertaking to make all these things talk to each other again. And if they don't nothing will work, not the radio, not the aircon, not abs, not traction control, not gearbox becuase they all have to speak to each other to work. Ok I exxagrate maybe the radio will work.
