Polo 1.9tdi problem
- Kingshill1@
Polo 1.9tdi problem
Good day guys
OK sitting bit problem i had time ago my cam belt on my tdi redone, i never had leaks or any water loss or any problem before this, ACD work on the car, now since i got the car back from them 2 months ago my car is using water suddenly i went back and they did checks again and also DIE test and pressure test and no leaks is showing. This is just very strange to me that since my car had cam-belt changed now its using water, i went then to second opinio to Goch and cooper and asked them to just check for me what can be wrong they then found radiator was leaking bit in bottom small crack, ok so then i replaced it and also replaced bottle cap and also sensor. I really thought that would make difference now but still same problem car is using water but like it will only drop in 4 days time. i really hope not head gasket as this is weird that all this started after cam belt change.
do any of you guys perhaps know what can be or had maybe a problem like this as i read all the other stuff guys wrote but mine bit different as my stuff happened after cam-belt change and i don't know maybe dud water pump.
- Kingshill1@
Re: Polo 1.9tdi problem
Any body perhaps have any input on this?
- Membership No: 2033
Mileage on car? What about at water pump? G12 has a die in it, check under black light / UV.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Tdi jetta 4 ever
Did they replaced the water pump ? Could be leaking at the water pump.
Robin
robinwisse@gmail.com
- Eddels
- Car Make: Seat
Could be waterpump leaking
My Seat Leon Cupra Thread - 240wkw and 525nm
My Seat IC Candy Project Ed Tuned - 281wkw and 711NM
Seat Ibiza Cupra tdi Silver - Stock
Seat Ibiza Cupra tdi Grey - Race Car
- Kingshill1@
Hey Guys
km on car now is 194000km car always been serviced by vw before 186000km. they replaced whole cam-belt kit with water-pump. its just strange that after replaced the cam-belt kit that the car is using water now and also another symptom that's is coming up is oil being used already checked all boost pipes and oil leaks on car nothing that i can see. but this also was after oil change might be that didn't put in enough.
- Kingshill1@
Do you guys know anyone in cape town that would be able to assist me with doing the head for cheaper if it is the gasket thats maybe damaged in between the pistons.
- amstel18
- Car Model: Tiguan Allspace
Go speak to ferdi at euromotorclinic in Willow road stilkland. Decent guy that won't take you for a ride.
Sounds definitely like they screwed up the waterpump.
If they put proper g12 coolant in the car you can trace water leaks with a black light
Sent from my HUAWEI VNS-L22 using Tapatalk
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Kingshill1@
thanks Amstel18 will go check him out and ask him to have a look for me also. will let know of feedback
- Kingshill1@
ok went to him hes gone check out for me if its maybe the waterpump. but strange enough this whole week no oil problems and no water lights coming on at all.
