Breaking up and misfiring
I have a 1.9 tdi Seat cupra, car has stock software and straight pipe only and noticed that when the car is cold and i accelerate it sounds like limmiter at around 3k rpm.) up and misfires and when i change gear the turbo dumping noise is louder than normal from the exhaust And if i continue to drive it a little hard and it warms up then the power is back and boost is normal.
Sent from my SM-G900H using Tapatalk
Re: Breaking up and misfiring
Why are you driving a cold engine hard?
- Unobeat
- Car Model: Uno, Auris, CX-5
Eish
Poor car, don't drive a cold engine hard as it is still warming up.
The temp is around 60 or 70 so its warm enough to pull to around 3000rpm I'm sure.
Scan, look at water temp and if it seems reasonable in the reading blocks, then look at injector deviation and see if it is in limits.
Can be caused by an iffy injector.
Your story has now changed as you said it does it when cold but not hot.
Ok i will check injectors and water temp. I noticed twice when it was cold and then i left the car to warm up to 70 or less and it still had the same problem. Sorry i did not explain properly at 1st.
Checked this on idle with vcds does the maf part look right and the idle speed running
Nope, that maf reading looks way high. Ws the car still cold because 38 deg temp is not a engine at operating temp. Injector deviation looks fine.
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
MAF reading looks correct, that's mg/stroke. 1900cc should pull around 475 (1900/4) mg/s at idle at the coast so 460 is ballpark for altitude.
Thanks for the repose.THANAS wrote:MAF reading looks correct, that's mg/stroke. 1900cc should pull around 475 (1900/4) mg/s at idle at the coast so 460 is ballpark for altitude.
Ah carp I didn't read the tag.. Looked at the 850 old age is cathing up now..
So the 850 is correct
So the 850bis correct and when i drivevthe actual should reach the specified maf of 850?
