TDI idle consumption
- Car Model: Sportline
- Membership No: 3194
Hello Gents
Wanted to get your opinion on something. My cars idle consumption is a bit all over the place. My previous 1.9 tdi idled solidly all day at 0.5 l/h and my current 1.9 tdi idle ranges from 0.6 - 0.8. Where would I start in figuring out the problem?
Specs:
Car: 2007 1.9 TDI Sportline
Software: Dimsport
Turbo: New only done 4000km + IC + piping
MAF: Cleaned
Cambelt: Replaced 40 000km ago.
Service: Full service done 2 days ago.
VCDS: Shows no errors. Injectors are also within spec and ( I THINK, not 100% sure ) timing is in spec 0.6
Consumption: 0.6L/h in the morning, after 10 minutes its 0.7 and coming home around 4-6pm its 0.8L/h.
Regards
Specs:
Software: Dimsport
MAF: Cleaned
Regards
Re: TDI idle consumption
Put the obc on something else. It won't bother you then . You worrying about 200ml/ hour?
It can be simply differing aircon load.
Last edited by panic-mechanic on Mon Nov 06, 2017 12:23 pm, edited 1 time in total.
Hahahahahaha ok so I am just being a little OCD and this actually means nothing?
I would struggle to explain how ridiculous it is to worry about something like that on a guessed consumption number.
Thank you. I am going to go to the shame corner now.
- Membership No: 2033
Wait until there is a problem to figure out.....this is not one of those instances.billionairebum wrote:Where would I start in figuring out the problem?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
To the OP:
I don't think it's shameful or OCD at all. I check idle consumption regularly (Note: after having switched off all electrical loads - lights, fan, aircon etc.). On a warm engine, mine is mostly 0.5 l/h, but sometimes it just goes to 0.6. I also make sure that the radiator fan isn't running, as this can increase it by 0.1 or 0.2. But, with no loads, it's almost always 0.5, and I would definitely start to wonder if it went to 0.7 or 0.8.
To my knowledge, the data comes from one and the same MAF, and if this is really so inaccurate and inconsistent, then I wonder how the ECU manages to inject the right amount of fuel consistently. But I'd gladly stand corrected...
If nothing else, you'll be glad to know you've found a kindred spirit. Let's go stand in the shame corner together.
- Neuk
- Treasurer
- Membership No: 806
I wish mine was 0.5l/hr at idle with the A/C off
- vee4410
Maybe it is timing related related. Try adjusting it slightly and see if it makes a difference.
2007 Polo 9n3 1.9 TDI
2004 Polo 9n 1.6
2015 MB w205 C180
2004 Polo 9n 1.6
2015 MB w205 C180
- amstel18
- Car Model: Tiguan Allspace
Moenie krap waar dit Nie jeuk nie
Sent from my HUAWEI VNS-L22 using Tapatalk
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- smitbrandon
+1amstel18 wrote:Moenie krap waar dit Nie jeuk nie
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
But the sound it makes, makes it worth while.Neuk wrote:I wish mine was 0.5l/hr at idle with the A/C off
Alternator and aircon load will easily make those differences. So unles you kill all consumers and then watch it for an hour I promise you there is nothing broken. No need to fiddle or repair anything. Again you a worried about a variation of less than a can of coldrink over an hour. Just stepping on the clutch will change engine load. The fans coming on and cooling the motor puts more load on the alternator thus changing engine load.
dont worry about this as panic said.
i noticed on mine it varies when changing brand of diesel then after a few 100ks it settles.
sometime 0.2, 0.1, 0.5 all depends how i come to a stop, when changing diesel brand goes to 1 sometimes
total consumption when filling at pump is what matters most to me
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
