Polo 1.9TDi cold start fast idle issue
- Shivbeanz
- Car Model: 9n Sportline
Hi guys,
For as long as I can remember, when cold starting my car, the car would idle at +-1000rpm and then drop to 800rpm after a few minutes of idling or blipping the throttle.
Recently when cold starting, the car immediately idles at 800rpm. I changed the thermostat a few months ago as the temp gauge on the dash never reached 90, changing the thermostat solved that.
Just wondering if this is a major issue and if anyone else has experienced this?
Other than this the car feels normal, just annoying my OCD as I know it used to do this "fast idle" before.
Any advice will be appreciated.
(Oo=o=oO)
Re: Polo 1.9TDi cold start fast idle issue
Not an issue. Don't lose sleep about it. When it's really winter the fast idle will be back.
- Car Model: 1.9 Tdi Sportline
I have a polo tdi sportline...96kw I am having a hot start issue...the car starts when it is cold however when I drive it to the shop or so and leave it about 10 to 15 mins and come start it again it struggles...can anyone shine light on this issue
- Carel040
Yes bro take it to someone that's got VCDS to scan your cab then u will know what the issue is
Did a scan previously the guys said transmission speed sensor and cam sensor took it to the mechanic he says the cam sensor is fine but he changed the trans speed sensor....so now its still doing the same thingCarel040 wrote:Yes bro take it to someone that's got VCDS to scan your cab then u will know what the issue is
- Carel040
Then take it to another Mac or person that can scan it for u , where are u based bro
Durban...Carel040 wrote:Then take it to another Mac or person that can scan it for u , where are u based bro
- Carel040
Contact toxic tuning bro
- Carel040
On the other hand if one sensor is playing up change both
I think I will change the sensor first
- vee4410
Change CPS and it will most likely solve our issue.
2007 Polo 9n3 1.9 TDI
2004 Polo 9n 1.6
2015 MB w205 C180
2004 Polo 9n 1.6
2015 MB w205 C180
I will do that this weekendvee4410 wrote:Change CPS and it will most likely solve our issue.
