DIY GASKET?
Tman21
Car Model: BosPolo
Membership No: 3247
DIY GASKET?
Post by Tman21 »
Hi Guys, I need gaskets for my EGR blank off plates.
Toppie at autozone didnt seem to know what day of the week it was let alone what an EGR or gasket is.
If DIY is possible what do I use and where do I get or where can I go looking for a gasket apart from agents? 2007 BT 50 3.0 Diseasel WEAT engine.
Thanks :moon:
Success: When hard work meets opportunity :-)
#TMAN21
Re: DIY GASKET?
Uhm. On the exhaust side you might have a problem but is there not an existing gasket. Refit with firegum.
Intake side regular high temp silicone sealer will do..
Tman21
Car Model: BosPolo
Membership No: 3247
Re: DIY GASKET?
Post by Tman21 »
Blank off plates were 1mm mild and the heat forced it open and destroyed whatever form of gasket there was.
Ill look for Firegum thanks. Will gooi a pic now of the leftovers
#TMAN21
TDIFlava
Registered for: 6 years 7 months
Re: DIY GASKET?
Post by TDIFlava »
As panic said high temp silicone on the intake side and use the metal existing metal gasket on the exhaust side should have no problems did it on my 1.9 TDI Polo works like a charm.
Audi A3 8p TDI (Decat, twin S4 tail pipes, 17" rims, SQ sound system) (103kw/420nm)
Polo Classic 9n3 1.9 TDI (Decat, SQ sound system)
Golf MK1 aka Gravedigger
Citi Golf 1.4 Sport (RIP)
Tman21
Car Model: BosPolo
Membership No: 3247
Re: DIY GASKET?
Post by Tman21 »
#TMAN21
Tman21
Car Model: BosPolo
Membership No: 3247
Re: DIY GASKET?
Post by Tman21 »
Intake side is still perfect, but ill be fitting a 3mm plate anyway. And im sure High temp will work there. My problemo she is on exhaust side.
Spread some firegum and gooi 3mm plate?
#TMAN21
Re: DIY GASKET?
What size are those things centre to centre. I have bery nice 4mm cut from stainless plate one made for them vw's. They look pretty much similar. You could even check at GW for a gasket....
Tman21
Car Model: BosPolo
Membership No: 3247
Re: DIY GASKET?
Post by Tman21 »
Lets hope this is bog enough. Can always modify the gasket to match studs as long as the seal around the edges.
#TMAN21
Tman21
Car Model: BosPolo
Membership No: 3247
Re: DIY GASKET?
Post by Tman21 »
So 38x67mm holes center to center is 45.5. I had 10 knocked out in an attempt to recoup . . .
#TMAN21
missioner
Car Model: '87 MK1 Golf Citi
Re: DIY GASKET?
Post by missioner »
What I normally do for an EGR blank off is to cut the OEM flange from the pipe and have it welded shut with 4 or 5mm plate. Refit with a new gasket from the dealer and done.
It's not pretty, but it works 100%, 100% of the time.
IIRC the flange is 6mm thick.
Tman21
Car Model: BosPolo
Membership No: 3247
Re: DIY GASKET?
Post by Tman21 »
Im no machy only swing spanners on the bikes but cant you get asbestos sheet or something to make a gasket from and then at little bit of gun gum or firegum?
#TMAN21
TDIFlava
Re: DIY GASKET?
Post by TDIFlava »
Leave the asbestos get a gasket from agents and use a thicker flange plate with firegum.
Tman21
Car Model: BosPolo
Membership No: 3247
Re: DIY GASKET?
Post by Tman21 »
Thanks Gents
#TMAN21
Ashveer03
Re: DIY GASKET?
Post by Ashveer03 »
Goldwagon has the gaskets, well they have for the 1.9 (not sure if yours is the same)
