Hi everyone,
I please need help on my polo 1.4tdi. Every 2/3 weeks I need to buy new water pipes for my car. We noticed if we took the pipes off there is diesel on the pipes which means there is a breath somewhere?... The pipes are swolen up, making a bubble on it then it starts leaking.
Any help please?
2003 Polo 1.4TDI
Re: 2003 Polo 1.4TDI
Diesel on the pipes as on the outside? If that is th case then start looking for a leak that drips on then pipe. And no other issues, water usage/ extra pressure in the water system?,
Diesel is on the outside yes. Car doesn't use any oil or water at all, checking that twice a week on my car, unless a pipe start leaking because of the diesel on it
- Sabretooth Tiger
Have you checked for diesel leaks, as panic suggested?
2021 Polo Vivo 1.4 Trendline
2015 Dodge Journey 3.6 V6 R/T
2014 VW Polo 1.2Tdi Bluemotion
2017 Tornado Red VW Jetta 1.6Tdi Comfortline DSG
2008 Hyundai Accent 1.6 3dr
2010 BMW 320d
2010 Mazda 3 2.0 Individual
1999 Nissan Sabre Gxi
2006 BMW 323i
2000 Opel Corsa Lite
2006 Ford Focus
1999 Nissan Sentra Gsi
1996 Toyota Conquest.
2010 BMW 320d
2006 BMW 323i
2006 Ford Focus
Ok you really need to find the diesel leak. Should be fairly obvious if it is that bad. Is it the same hose that fails or differnt ones.
It was twice the same one now. Pipe is on the right side of engin at the back/corner. Will try and take a photo later aswell
if it is the same pipe then that are must have the leak. A photo will help for sure.
Probably a tandem pump leak as there are no fuel pipes on rhs back corner of the engine
