Hi,what and how can i check to fix the air coming through the airvents better,if i put the fan on speed 2 ,3 or 4 the flow of the air coming out is very little,same with when you switch it to the feet,no air is oming out,also the flow in the center arm compartment facing to the back passengers also haven little to no airflow.what can i look out for to fix this?
2009 jetta 1.9 tdi air vents
- Mr.G24
- Car Model: MK5 Jetta 1.9 TDi Comfortline
2008 VW Jetta 1.9 TDI Comfortline (Reflex silver)
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Re: 2009 jetta 1.9 tdi air vents
Remove pollen filter... see if the flow is better. If it is replace the pollen filter.
You'll be surprised how verstop that thing can get!
- Pynoxim
Friend had the same issue with his Jetta. Turned out to be the blower motor, common issue too, his picked up as an error on VCDS too.
- Mr.G24
Turned out that the pollen filter was so dirty,reason for the restriction of air through the vents.thanks for the help,oh the blower motor seems fine and blowing strong.
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
