White smoke on hard acceleration TDI ASZ
- Car Make: VW /Honda
- Car Model: TDI sportline/CRV
been a while since i posted and enjoying the daily car.
Just some issue wanted some feedback on before getting worried.
my polo seems to give off a puff of white smoke under hard acceleration which then dissapears
Noticed it ever since i filled up at the Shell in Oakglen.
i am thinking it good be the diesel or "breather oil" or worst case turbo ?
there is no loss of power and car feels same as when i bought it.
any advice to steps to troubleshoot further would help i will also provide any feedback required on my side and will be posting results as well.
car has STG 1 STO and downpipe
RM3 Honda CR-V / VW Polo 9n3 TDI sportline
X Jazz EX-S ,X Honda Accord Type S ,X Subaru Impreza STi 6,X Nissan 200sx,X 20v Corolla RXI,X Honda Civic vtec ,X Sentra 200sti
X Honda 180i SO4,X Rsi Twincam
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Re: White smoke on hard acceleration TDI ASZ
Could be oil seals on the turbo that's on it's way out. How many km's do you have on the turbo, also, what's your milleage on the car
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Car is on 125000km , turbo recall done by VW at 80000km
Murphys law, may not have anything to do with the fuel or possible they had contaminated diesel that poked your injectors, or the turbo is on the way out, but 80000km is recent, possible that the injector seals are pokedDunn wrote:Hi guys
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
- Car Model: S3, Polo Playa,
does it start first turn in the morning or when parked for a long time, if no! its the injector seals, it leaks thru, when driving a lot check your oil if its not very thin, cause is diesel leaking into oil via cylinder,
starts first time, it's my daily so only stands weekends.
I have filled up this morn with Engen 50ppm and a bottle Wynn's diesel injector cleaner.
Will see how it goes and provide some feedback
still gives a small puff under hard acceleration otherwise no smoke, will get it checked at next service and update here.
Even i am beginning to think this could be oil seals starting to go on turbo.
no other issues
no other issues
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
What part of the exhaust has been removed? Removal of particulate filter could result in more soot being released. There could also be a bad batch of fuel. Try a different brand like Sasol 10ppm for a while and take it from there.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
Hey bud ,DPF is removed
Will give Sasol a go ,thanks
Was unable to login to update
Polo all sorted now after a service and using caltex in my area for now
mechanic says i should be prepping myself for camshaft replacement :-
Have you been using the right oil?
car has had full service History with VW before , i am the first owner to take it to non dealer mechanic
Did he r move the tappet cover to look at the cam or based on what kind of clearvoiance does the camshaft replcement advice come from?
well after cambelt service he said he checked it out and with the service now , it's showing signs of camshaft/Lifter wear.
Then showed me a broken PD100 camshaft in the shop.I have a warranty plan on this car as it's my first diesel,:)
contacted them and they will cover, provided an assessor checks and they get some pics sent through.
Forgot I had this post here, but save people trouble in future. This was the oil seals in the turbo. I had them replaced but then later had the shaft break on exhaust side from overheating due to a block oil feeder pipe. Not nice finding bits of the blade in exhaust filled with oil. Could have been much worse.
So had to fit a 63mm with 1 box with sort out exhaust issue.
