X Polo Tdi 6R - DPF Revoval
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 & A3 20VT & Mk 1 Jetta GLi
Post by P1LAYA-ZN » Fri Aug 22, 2014 4:07 pm
Good day gents,
As I am soon to be taking over my gf's car, I would appreciate some advice.
The car will be around 150000 kms when I take it over and I was wondering if its advisable given the mileage for a 3 yr old diesel, doing the DPF removal ?
I've read up that this will help with saving the turbo, increasing fuel economy and power?
Is it worth doing, and what gains can be expected after doing a mild map ? Also, will the car start throwing out clouds of black smoke ?
#Builtnotbought
J.R Caddy
Car Model: MK1 Caddy
Re: X Polo Tdi 6R - DPF Revoval
Post by J.R Caddy » Sat Aug 23, 2014 9:54 am
Wont suggest removing the dpf, as it is not a normal catalyst. The management uses it. If you remove it , the warning lights will come on the dash and go into limp mode :type: the power will dissapear. Check in thle owners manual. It tells you how to burn it clean if neccesary. When it starts goetting clogged the dpf warning light will come on. Any vw can burn it clean for you using diagnostics. When the warning is active. If you do remove it. And therr are issues. To replace it will cost you in the area of 25k. :crazy:
MouseGTI
Car Model: B7 20vT
Post by MouseGTI » Sat Aug 23, 2014 10:10 am
Will need software if you remove it....to keep the engine management happy
sent from small tehbo
White '07 Polo GTI 9n3 - Stock
Black '07 Polo GTI 9n3 - 113fkw 234nm stock -> 153kw 277nm chooned
Green '16 Kawasaki Z300
28kw 27nm @ 11k rpm :crazy:
Silver '07 Slowdi A4 B7 1.8t - w/ T3T4 powers
141kw 278nm w/ KO4-0015
FKn Coilovers : 76mm DP + zorst : 101mm zorst tips : FMIC : IE Coil Spacers : Moar IE stuff : Neuspeed Short Shifter : BFI Weighted Knob : Cupra Lip
Punisher187
Car Make: Polo 6R
Car Model: 1.6 Tdi
Post by Punisher187 » Mon Sep 22, 2014 12:16 pm
First thing you should do is remove the DPF(they remove the insides of it) then go to a tuner who will remove the dpf out of the software.The Dpf regeneration is a pain in the @$$
thabom99
Post by thabom99 » Fri Feb 23, 2018 5:47 pm
Hi all
I have a clogged catalyst conveter and have found one at a scrap yard. Can I go ahead and replace it. I'm not a mechanic.
