1.9 tdi electrical problem
- Scotty_88
- Car Model: Polo TDI sportline
So driving today and I lost all power steering and the steering wheel light shows on the dash, steering was heavy-scary stuff! Not long after get an abs failure. Pull over, turn ignition off and restart. All is good again. 5 mins later same thing again. Restart and problem goes away, rest of the day all is good.
Now went to my car and central locking won't work, get in and the dash is blank(no power), turn the key and power is back on but computer has reset. I have checked battery voltage,fuses and terminals and no issues as far as I can see. Anyone care to help? Electrical problem for sure but where to start is the question?
Thanks in advance
Thanks in advance
- Car Model: 12' Golf 6 GTI
Re: 1.9 tdi electrical problem
Check the earth cable to the body
'12 VW GOLF 6 GTI
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'07 VW Polo Gti - Revo 2
'10 BMW 320i E90 Msport
'05 BMW 318i E46 Msport
'93 Golf CTi
'86 Mazda 323
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'93 Golf CTi
'86 Mazda 323
- Chuck_Norris
- Car Model: Polo 1.9 TDI
Mine does the same.
http://vwclub.co.za/forum/viewtopic.php?f=94&t=157575
Also think it the earth cable, from the battery to the body. Just didn't come around to replace it.
Ex - 1.9tdi Highline
http://vwclub.co.za/forum/viewtopic.php?f=11&t=161270
Current - Tiguan 2.0T - 4 Motion
http://vwclub.co.za/forum/viewtopic.php?f=11&t=183069
- Scotty_88
checked it, what exactly am i looking for?dees@pgti wrote:Check the earth cable to the body
Least i am not alone, so what you just not going to fix it? how often do you have this problem? I see on that thread a member reckons its cold weather or something. Pretty much impossible i mean this is DurbsChuck_Norris wrote:Mine does the same.
- Chuck_Norris
Mine was maybe once a week. Took the cable off, sanded all the connections on the battery and the body. As well as the connection points on the cable. Also took the pliers and make sure the join between the cable and the connection points is tight.
- Scotty_88
Yeah going to do the same, get all the connections nice and clean and get better conductivity, perhaps a spray of wd40 too. Thanks for the help. Thought it was in for a new power steering pump(10k). Sheeew...
- TimeShifter
- Car Model: 2012 Mk6 GTi
How old is battery? If its not that earth, its the battery for sure! It might have the right voltage but doesnt have enough "power". Have it tested.
2012 VW Golf Mk6 GTi
- Tdi jetta 4 ever
Just make sure that there is enough power steering fluid in the resoviour.
Robin
robinwisse@gmail.com
- B_rad
- Car Make: Ford
- Car Model: Fiesta ST180
- Membership No: 1835
WRT the battery, also check that the terminal is not 'caked up' with acid. The acid goes up the earth strap and causes problems as well.
- Scotty_88
ok thanks for all the replies guys, very much appreciated
So earlier went out and had the same issue, hids began to flicker on and off then the power steering light came on and lost all power steering then followed by abs failure light and then handbrake light.Pulled over and turned ignition off and then there was no power, dash went blank. The car had zero juice could not even start it
Opened up the bonnet and gently tapped the earth cable which runs to the body and bang power back on and everything is hundreds again. So happy as now I know its the earth that is has a bad connection, will sort it out tomorrow and if i don't come right will go visit the stealers
amazes me that that little connection can cause such crap and can be so unsafe(lost power steering round a corner today).
- Chuck_Norris
Cool, let us know what is the costs of the cable. Will get mine replaced then as well.
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Doubt you have to replace the earth cable, just clean it and fasten everything again. Mine did the above and it was the battery!
- Scotty_88
Ok so the problem seems to be sorted now, removed the earth strap and sanded the connection points and gave the point on the body a spray with Wd40. The wire itself was pretty dirty/Oxidised to gave it a good clean and wd40. Driven 100km today and all seems good. Thanks to those who helped, saved me lots of cash and time
- Tdi jetta 4 ever
What is this WD40 you guys are talking about?
Robin
- Chuck_Norris
Q20
Glad you sorted out dudeScotty_88 wrote:Ok so the problem seems to be sorted now, removed the earth strap and sanded the connection points and gave the point on the body a spray with Wd40. The wire itself was pretty dirty/Oxidised to gave it a good clean and wd40. Driven 100km today and all seems good. Thanks to those who helped, saved me lots of cash and time
'12 VW GOLF 6 GTI
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'93 Golf CTi
'86 Mazda 323
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'93 Golf CTi
'86 Mazda 323
Hi guys please help my 1.9 tdi rev counter is jumping engine light on and asr ,abs ,handbrake did check with vw and nothing faulty have the ecu re-solder then work for day or 2 then back at the beging please help.would like to post video that you can see but don't now how.
