Spitronics Management On a 3.2 Vr6 Fsi Engine...DSG
Stuta
Car Model: MK5 R32
Post by Stuta »
:? I totaled my mk5 R32 engine ...3.2 vr6 DSG
So i removed it...
And i got another engine from a passat b6
3.2 vr6 Fsi DSG as well...that i installed in the Golf
Engines are the same but because of the Fsi on the engine i got...the management nd the injectors differs...
Connected to the r32 ecu...
I get spark and all...
But the ecu does not recognise the injectors
And then there are 3 plugs on the fsi feul rail
That are missing from the r32 harness...
Wil an aftermarket ecu run my engine..? (Spitronics)
And wat happens with the dsg gearbox...?
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Re: Spitronics Management On a 3.2 Vr6 Fsi Engine...DSG
Post by THANAS »
Just swap the intake and fuel rail and everything from the old motor and blank off the direct injection holes,then you can run the oem management.
You will have no luck trying to run aftermarket management on a DI engine.
The Snail
Car Model: MK4 GTi
Post by The Snail »
Injector ports are on the head, not the manifold. So you cant swap it over.
ex. Golf 4 GTi AGU/AUQ
t3/t4 50 trim .48ar
260kW and 390nm
Eurodyne maestro software
Audi 3.2 vr6 Turbo
323Kw and 660nm @ 0.7 bar
The Snail
Car Model: MK4 GTi
Post by The Snail »
I actually cant think of any work around :/
t3/t4 50 trim .48ar
260kW and 390nm
Audi 3.2 vr6 Turbo
THANAS
Membership No: 2035
Post by THANAS »
Aaaah flip yeah, forgot about that.
