cti 1.8 91 fuel inject
vehicle starts, but runs only for till it runs out of fuel(5min) or thats wat it sounds like. bought second hand. secondary fuel pump hav bn replaced and new pistons installed. could the primary fuel pump be at fault, could there be an immobiliser that i dont know of, could it be my oil sensor? friend mentioned something about cage elictronics problems with the fuel injections. pls help. thanks
- chucker02
- Car Model: Citi ADY
Re: cti 1.8 91 fuel inject
Can be alot of things
1971 VW beetle
1971 VW beetle
narrow it down?
- chucker02
Just saying your info is not enough, we are supposed to diagnose your car with 1 sentence and how should we know if your car has an immobilizer?
1971 VW beetle
1971 VW beetle
ill first confirm that there is or is not an immobiliser. gave the car a swing today and it ran for about ten minutes, i switched it off, gave it a minute or so nd did not start, it swings nd all
- Car Model: MK3 Jetta 1.8 CSX, 1976 Beetle
I would do the same thing again and check if there is spark if so make sure that fuel is going through, but that's just me.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
- Membership No: 1893
Moved topic to correct Thread.
Ex's:
'07 VW Golf MK5 GT - SOLD
Ex's:
if it was immobilizer it would not run for any amount of time. Will start and die or never start.
K-jet can be many things. They work on pressures and if you can't test that you can guess forever. When it dies is there still spark?
