Hi,
I have a citi golf 1.4 and recently changed the front left bearing and Hub including the inner and outer CV joint also on the left hand side. I also put 2 new front tires and did the wheel alignment .This was about three weeks ago and now suddenly the car seems to pull to the right hand side when Excelerate. There is also a cluck noise when I excelerate and then she pulls to the right . when I release the Excelerator she seems to correct. What could be the cause of this problem?
Car drifting to the right
- amstel18
- Car Model: Tiguan Allspace
Re: Car drifting to the right
well what caused the issue in the fisrt place that you only replaced the left suspension parts?
As a rule of thumb, I replace everything suspension related in pairs. Both left and right...
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Well my front left hub was shaking when driving, when changing it we found that the wheel bearing and left cv joints inner and outer was all stuffed. I'll take it to the cv guy to check the right hand side... It just seems odd that it pulls to the right.amstel18 wrote:well what caused the issue in the fisrt place that you only replaced the left suspension parts?
