Summit White Chevrolet Utility - Detailed by Lawrence
- Lord of the Sponge
- Membership No: 1676
This vehicle is still new and had been parked close to a company who were painting. Unfortunately for the owner, his car was covered in what appeared to be yellow paint. Fortunately however the company was more than willing to rectify the situation, and so the vehicle was booked in with the main aim being to remove the yellow paint from pretty much every exterior surface, polish the paint to remove the inevitable marring from claying process and restore its gloss, and re-protect everything. No work was carried out on the interior or engine bay.
Starting with the dirty area including the wheels, brake calipers, tyres and fender liners so that any potential splashes of dirt onto the paint will be washed off during the 'paint' wash, and therefore if you were to have splashed some dirty wheel water onto the paint, you would only have to wash this area once, instead of twice, and therefore would reduce the potential for swirls.
These were cleaned using a combination of Valet Pro Billberry @ 1:5 and Carchem APC @ 1:5 with a variety of dedicated brushes and mitts. The painted sections were protected using Carpro Hydro and the plastics with Carpro PERL.
Before
The little black dots are from some form of silicone based dressing which (invariably) gets over-applied, and has slung up onto the paint.
Horrible design means dirt collects here really easily
During
After cleaning (but before the tyres and plastics were dressed)
The entire exterior was then cleaned using Turtle Wax Hyperfoam through a foam cannon, Carchem Luxury Shampoo (with 2 buckets / grit guards / wash mitts) and Carchem APC in order to remove the dirt which had not bonded to the vehicle. The vehicle was then pressure rinsed, and liberally sprayed in Carchem Revolt, which was allowed to dwell in order to "dissolve" the embedded iron particles in the paint, the resultant color change of which can be seen as the purple'ish / red'ish bits in the photos below. Where needed (if it appeared sections would risk drying out) I re-covered the area with foam from the cannon.
Carpro Tar-X was then used along with cotton discs and plastic razor blades (where required) to remove the tar contaminants before I was finally able to tackle the paint over-spray.
I used a little over 200g of Shield Heavy Duty Clay along with a couple of litres of clay lube.
Many hours later I was able to tackle restoring the actual paint, which mostly looked like the below and not how a car this young should look.
After a few test spots I settle on a 1-step correction using Flex 3401, Lake Country Orange Hybrid Pads, and Turtle Wax T10 polish. Here is a before and after on the bonnet.
The paint was then protected using Turtle Wax Perfect Finish Paste Wax. I had no problems during application or removal, but did note it tends to haze up rather quickly. I didn't risk leaving it too long before removing, so work smaller sections at a time.
The remaining exterior plastics and the loadbin cover were deep cleaned using Shield Heavy Duty Vinyl and Rubber Cleaner, before being dressed with Carpro PERL.
Before
After
The glass was cleaned inside and out using Meguiars Perfect Clarity Glass Cleaner
I was unable to get the vehicle out of the garage for any 'nice' after shots, so the below have to suffice .
Total time spent = 27 hours.
Thanks for looking and as always any questions or comments are welcome.
Before
During
Before
After
- Belix
- Car Model: Passat B8
Re: Summit White Chevrolet Utility - Detailed by Lawrence
Would not think you see a half tonner all that often! Good stuff Mr E
- Car Model: Q5
- Membership No: 1964
As always, great work Lawrence!
- Sabretooth Tiger
Damn, that's impressive work man. Looks better than brand new.
2021 Polo Vivo 1.4 Trendline
2015 Dodge Journey 3.6 V6 R/T
2014 VW Polo 1.2Tdi Bluemotion
2017 Tornado Red VW Jetta 1.6Tdi Comfortline DSG
2008 Hyundai Accent 1.6 3dr
2010 BMW 320d
2010 Mazda 3 2.0 Individual
1999 Nissan Sabre Gxi
2006 BMW 323i
2000 Opel Corsa Lite
2006 Ford Focus
1999 Nissan Sentra Gsi
1996 Toyota Conquest.
2010 BMW 320d
2006 BMW 323i
2006 Ford Focus
- Kyle
- General
- Registered for: 11 years
- Car Make: Porsche
- Car Model: Adidas TYP 64
- Membership No: 1922
Most guys hate detailing a white vehicle, but I actually find it quite satisfying..
Nice work as usual bud, well done!
Thanks for all the kind words guys
- Crazydetailer
- Registered for: 20 years 8 months
Nicely done Lawrence. Thanks for the great write-up.
Store Tel : 011 476 5409
- Uvy
- Car Make: VW and Seat
- Car Model: MK2 GTi 16V Golf
- Membership No: 1740
nice job LA
Heaven on Earth - VAG for life
- Unobeat
- Car Model: Uno, Auris, CX-5
Great detailed write up and the silicone used on tyres it seems majority of car washes use that to dress the tyres and yes as you said they over or terribly apply it.
Paint work looks 105% better.
Thanks PravinDjin wrote:Nicely done Lawrence. Thanks for the great write-up.
Thanks buddyUvy wrote:nice job LA
Thanks. Yes silicone based dressings are really something I think everyone should move away from but its cheap and used by most car washes, so the general public is used to seeing gooey shiny stuff on their tyres (and down the sides of the their cars, if they bothered to look)Unobeat wrote:Great detailed write up and the silicone used on tyres it seems majority of car washes use that to dress the tyres and yes as you said they over or terribly apply it.
