Lamborghini Aventador Roadster - Detailed by Lawrence
- Lord of the Sponge
- Membership No: 1676
This beauty in a color called 'Grigio Estoque' belongs to a good customer of mine who recently purchased from the original owner, who was using it as a daily
This was the first time I've ever been near any Lamborghini, so I was as excited as a little kid on Christmas at the thought of spending 4 days up close and personal with one, and it lived up to all my expectations, and more
A couple of quick thoughts...
- The way it sounds on start up (especially in the garage) is just
- The way it sounds when the owner leaves and gives it beans up my road is even better
- Its wide (the middle of the engine bay area is tough to get to)
- Its low, and getting in and out is interesting
- You can't see much of the front end when driving it in or out my garage - I won't lie, I was a tad nervous
- Cleaning the inside of the front windscreen was by far the toughest one I have done - it's deceptively big and the angle with the dash, the the shape of the seats and centre console, means you need to be a contortionist. I'm not.
So let's get detailing....
Engine bay
Just look at it. A 6.5l V12 making 515kw / 690nm that rockets it from 0-100 in 3s flat and on to 350km/hr
But it needed a clean.
After covering up any sensitive areas the underside of the carbon fibre engine bonnet was given a HP rinse, sprayed with Carchem APC which was left to dwell, before being agitated with various brushes and MF towles and HP rinsed again. I then repeated this process on the entire bay itself including all the plastics, and then dried everything with a blower.
As you can see here, the underside of the engine cover/bonnet didn't look so great.
After trying many glazes and AIO's, then only thing that really worked ok was Meguiars #7, worked in by hand with a MF applicator pad and buffed off.
The carbon fibre cover on the middle of the engine was hand polished using Meznerna 3-in-1
Wheels
A beautiful set of Khan Santagatas in Silver Platinum
The car is fitted with Carbon Ceramic Brakes and so if you were to get any chemicals on the rotors or pads, they would absorb the chemical as they are porous, causing damage. So I used plastic bags to cover these areas up to avoid an eye watering replacement cost.
I then HP rinsed the fender wells, tires and wheels. The plastic fender liners in the rear fender wells were cleaned using Carchem APC and various brushes. Regular maintenance washes with a gentle PH neutral cleaner would negate the need for a deep clean with stronger chemicals, but in this case I had to use Angelwax Billberry Wheel Cleaner through a foaming trigger spray bottle.
And used it on the tires too
Leaving the tires and wheels clean
Once the car had been pulled back inside the wheels were dried and given a coat of Menznera Powerlock which was left to set up for about an hour, then wiped off and left to cure until the following day, when a 2nd coat was applied.
The tires were also dressed with 2 coats of Carchem Tire and Trim Gel
The plastic fender liners in the rear fender wells were dressed using Autofinesse Dressel, which was sprayed on, left for an hour to settle and then buffed to ensure an even finish with no excess product left behind.
Wash
First, a thorough HP rinsing to remove any loose dirt
Then Angelwax Fastfoam was applied and left to dwell to help soften the remaining dirt
During which time the honeycomb grills and emblems were agitated
The foam was then HP rinsed off and the car washed using multiple lambswool wash mitts, 2 buckets with grit guards and Carchem Luxury Shampoo in some warm water. Another HP rinse followed by a flood rinse and then I (carefully) pulled the car back into the garage where she was dried off using a combination of a blower and waffle weave drying towels with ONR as a drying aid.
Decontamination
There was a fair amount of contamination on the car and so Shield Heavy Duty Clay was used with ONR as lube - this included all painted surfaces as well as the outside glass (including the panes of glass in the engine cover/bonnet - but more on that later).
Paint Correction
Prior to detailing the car I had watched an episode of 'How its made, dream cars' on the Aventador in which they explained how the painting process involved 200 man-hours. You would think with that much time invested, the paint would be perfect, but sadly it wasn't. The car was riddled with sanding marks that were not removed at the factory and with the paint being hard, I had my work cut out for me.
The engine bonnet/cover, wing and side air inlets are made from carbon fibre, the roof from a different type and the rear fenders and rocker covers from yet another type.
The front fenders, doors and bonnet from aluminium
Where I could obtain paint thickness readings, they ranged from 221µ to 389µ
With so many sharp angles and edges a lot of taping was required in preparation for correction.
The color made it quite difficult to capture the defects and you may have to zoom in on some of the pics to see better (sorry)
The gloss black section around the front windscreen
Before
After Flex 3401 | Menzerna FG400 + Orange Lake Country Hybrid | Menzerna SF4000 + Black Lake Country Hybrid
Rear fender before
After Flex 3401 | Menzerna FG400 + Wool Lake Country Hybrid | Menzerna SF4000 + Black Lake Country Hybrid
Some sanding marks on the bonnet (to the left of the bottom light reflection) before [zoom in]
Some etching on the bonnet (look in the left light reflection) before
A close up
After sanding with 3000 grit
Protection
The car was wiped down with Gyeon Prep to remove any polishing oils and ensure the paint was 100% clean to allow the sealant to properly bond.
I then applied a coat of Dodo Juice Iron Gloss, working panel by panel.
The following day I then topped this with a coat of Dodo Juice Purple Haze.
Exhaust
This was polished using Meguiars NXT All Metal Polish [no pics, sorry]
Glass
These glass panes located in the engine bonnet/cover were riddled with water spots, primarily where the 2 panes overlap - I presume whomever has been washing it has found it too difficult to dry there properly.
Before
After using Mothers California Gold Water Spot Remover for Glass by hand some improvement was noted
After hitting it again (never-mind the lint on the glass - this would obviously be cleaned off later)
The interior glass was cleaned using Autoglym Fast Glass.
The exterior glass was clayed using Shield Heavy Duty Clay and ONR as lube.
The exterior of the front windscreen was polished using Autoglym Glass Polish | Flex 3401 | Lake Country Green Polishing pad
All the glass was then given 2 coats of Wynn's C-thru
Plastic Honeycomb
This was cleaned using Shield Heavy Duty Vinyl and Rubber Cleaner on a little 'foam stick thing' I picked up at an art store, which fitted perfectly and worked really well, but didn't last all that long - it broke 90% of the way in, but with the amount of honeycomb grills on this car, it probably equates to using one per 'normal' car (say like a golf 6 Gti or similar).... but for the price I paid for it, it's well worth not having to try squish your finger wrapped in a MF towel through the little holes to get the corners clean.
It was then dressed using Autofinesse Dressel
Interior
All loose dust was blown out and the the interior vacuumed. The leather was cleaned and protected using Collinite 855. This is the dirt that came off the passenger side of the dash board.
The plastics were cleaned using Carchem APC and protected using Aerospace 303 Protectant.
And here are some after shots that I took. It was about to start raining and I was in a hurry and inadvertently left the nose raised - kinda messed up the after shots, but it is what it is....
Some with my cell
Inside the garage
And outside
And some with the DSLR
[URL=http://s1217.photobucket.com/user/polo_ ... 9.jpg.html]
Total time take = 38 hours
Thanks for looking and as always, any comments or questions are welcome.
Engine bay
Wheels
Wash
Decontamination
Paint Correction
Before
Rear fender before
A close up
Protection
Exhaust
Glass
Before
Plastic Honeycomb
Interior
Some with my cell
Inside the garage
And outside
- Registered for: 9 years
- Car Make: Volkwagen
- Car Model: CW Polo 6R GTi
Re: Lamborghini Aventador Roadster - Detailed by Lawrence
Lawrence
Top work bud!
Top work bud!
- Car Model: A3 1.8TFSI 8P
What a car to be once used as a daily
If you aint first, your last !!!
As always, a very interesting read. I can only imagine how careful one would have to be due to the amount of angles on this ride.
well done Lawrence, an outstanding job there dude.
- francois_gti
- Car Model: RS Mk5 Gti (Manual)
- Membership No: 3041
Gosh awesome work. Well done.
Sent from my HUAWEI MT7-TL10 using Tapatalk
Current: Mk5 Gti
Ex: Audi A3 1.8T
Ex: Citi Life 1.6i
Ex: Citi 1.6
Ex: Cti 1.8i
Ex: Audi A3 1.8T
Ex: Citi Life 1.6i
Ex: Citi 1.6
Ex: Cti 1.8i
- Membership No: 1604
Wow looks awesome bud....
Sure it was nice detailing a Lambo...
- Car Model: Polo Vivo
WOW! Epic work bud
Can only imagine how amazing it must have been to work on this
Anees Hoosen
OEM+ '14 Polo Vivo
H&R l OEM Audi Sline 17's l PGTI Goodies l Jabsport Lighting
Past
'02 Polo 2.0 8V
OEM+ '14 Polo Vivo
Past
'02 Polo 2.0 8V
Thanks budmikhail117 wrote:Lawrence
Top work bud!
I guess if you can afford to, why not?UzziB wrote:What a car to be once used as a daily
Thanks very much.uzzi777 wrote:As always, a very interesting read. I can only imagine how careful one would have to be due to the amount of angles on this ride.
Thanks Francoisfrancois_gti wrote:Gosh awesome work. Well done.
Thanks - it was really nice. I couldn't stop staring at itOREO wrote:Wow looks awesome bud....
Thanks Anees - it was certainly a highlight of my detailing careerAnees wrote:WOW! Epic work bud
- kripstoe
- Registered for: 15 years
- Membership No: 1379
Impressive. Well done.
Current: '21 Audi 8V S3 Sedan S tronic
Ex: '15 Mk7 Golf 2.0 TSI Performance Pack DSG®
Ex: '13 Mk7 Golf 2.0 TDI Comfortline
Ex: '10 6R Polo 1.6 TDI Comfortline
Ex: '06 9N3 Polo 1.9 TDI Highline
Ex: '98 6N Polo 1.8i Lux
Ex: '96 Chico 1.3... it was green
- Car Model: Q5
- Membership No: 1964
Lawrence you are the man!!!!
Again, I enjoyed the write up. This came out tops bud
- Justin_B
- Car Model: Up!
- Membership No: 2024
Wow! Epic work! I would not be brave enough to take sandpaper of any grit to a **** lambo!! Well done on the end result.
Sent using the force...
- Registered for: 8 years 3 months
Epic work! What an awesome car too!
- jippo
- Car Model: ST
Another great job. Well done.
I'm sure it must be stressful working on the engine and brakes on a car like this.
F30 320d
ex: Focus ST250
ex: Focus ST250
Thank youkripstoe wrote:Impressive. Well done.
Thanks very much bud.Mbuzi wrote:Lawrence you are the man!!!!
Thanks Justin.Justin_B wrote:Wow! Epic work! I would not be brave enough to take sandpaper of any grit to a **** lambo!! Well done on the end result.
Well the etching really would have detracted from the rest of the car so it needed to come out, and I'm confident enough in my abilities. At some point, you have to switch your mind off to what lies beneath the paint (in this case a Lambo in other cases it could be a work bakkie) and focus your attention ON the paint....
Thank you.Spooln_4 wrote:Epic work! What an awesome car too!
Thanks bud.jippo wrote:Another great job. Well done.
The first time I encountered Ceramic Brakes was on the 458 Italia I did a couple of years ago - that was bloody stressful. But I've done a few since then, and it's all about prep work and making sure no chemicals get on the rotors or pads.
Engine bays (even on a normal car) are stressful - I think if you throw caution to the wind and don't repspect what you are doing, things will go wrong and so being afraid of messing something up ensures you again prep the bay and cover off sensitive electronics to mitigate the possibility of the risks coming to fruition. But the risk is always there. To negate the risk people often chose a 'cosmetic' engine bay clean (wiping off dirt + dressing the bay) instead of an all out full clean involving water etc.
- Sebz
- Car Make: BMW
- Car Model: 135i E82 N54 ST 6MT
- Membership No: 3020
Awesome to see that you do your research.. No wonder Jason says you're the best
Single turbo BMW 135i N54 6MT
Ex's:
Brilliant BMW 135i E82 N55 6MT
Stupidly static THANAS Tuned '05 Audi A4 B7 2.0T FSi
Definitely down-to-earth '03 Audi A3 8L 1.8T
Ludicrously lowered K04 '03 Audi A4 Avant B6 1.8T
Sorta slammed '15 VW Polo Vivo GT 1.6
Stock standard '05 Opel Corsa D Ute 1.4
Ridiculously reliable '81 VW Passat CSL Estate 2.2 5-pot
It's not how you stand by your car; it's how you scrape your car. You better learn that.
Ex's:
- Aveezy
- Registered for: 12 years
- Life160
Well done bud!!
Awesome car and a great end result.
- Morné Pieters
- Car Make: VW & Mercedes-Benz
- Car Model: 07 1.9TDi & 09 C350 CDi
Excellent work sir as always, well done!
2007 White Polo 9N3 1.9 TDi (PD100) - Daily Ride (Odo 306 000 km)
PD160 Intake lPD130 Intake System lEGR Blank lPD130 Turbo lDe-Cat lStraight Flow FMIC (450x230x65 mm) & 50 mm S/S Boost Pipes lWulfchip Software lFK Projector Headlights & 6000K HID lLED Retrofit lCustom LED Footwell Lighting lCustom Leather Interior lGTI Black Interior lCustom Speedo Cluster lCruise Control
Lovely car, great detail and write-up.
- Le Clue
- Membership No: 1458
Awesome work as usual.
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- DINODENASH
- Car Make: BMW
- Car Model: BMW e46 Individual
Amazing work !
you amaze me all the time !!
- Unobeat
- Car Model: Uno, Auris, CX-5
Oh my goodness Lawrence, what an EPIC write up and car.
#MuchRespect
#MuchRespect
Thanks budSebz wrote:Awesome to see that you do your research.. No wonder Jason says you're the best
Thank you very muchAveezy wrote:Your work is amazing!!!
Thanks budLife160 wrote:Well done bud!!
Thanks LeeQuietLee wrote:Lovely car, great detail and write-up.
Thanks MornéMorné Pieters wrote:Excellent work sir as always, well done!
Thanks Le ClueLe Clue wrote:Awesome work as usual.
Thanks DinoDINODENASH wrote:Amazing work !
Thanks buddy!!!!Unobeat wrote:Oh my goodness Lawrence, what an EPIC write up and car.
#MuchRespect
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Wow, ok be honest, how many times did you start it just to cream yourself?
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
