Headunit recommendations please.
- Car Model: Sportline
- Membership No: 3194
Hi
I am in the market for a new HU with Bluetooth and hands free calling with a mic. Single DIN or Double Din for a polo 9n3. I used to own a JVC kd-avx33
which did everything I wanted. Any recommendations would be great.
Regards
Regards
- NHB_R
Re: Headunit recommendations please.
JVC kd-avx33
- smashedmink
- Committee Member
- Registered for: 10 years 9 months
- Car Model: VW Fox
- Membership No: 1929
I am personally a huge fan of Alpine head-units, from entry level through to top of the range
Current: 1991 VW Fox 1600L
Ex: 2003 Mk4 Golf GTi
132hp/98.5kw & 204nm atw @ Oettinger Edenvale
Ex: 1998 Mk3 Jetta CLi 2.0
116.6hp/87kw & 179nm atw @ Stealth (Coastal + NF 5ron)
Any Alpine HU you would recommend that is on par with the other one?
- Wolf Mk2 16V
Bought this for Wolf, fitting the weekend!
https://www.crutchfield.com/S-MD3pYKpWu ... V-700.html
Unfortunately not available in SA, blind luck that I found it...
I use Pioneer Bluetooth receivers in my work vehicles: Pioneer MVH-X395BT, the hands free is just just okay nothing to write home about
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
- morribiscuit
- Car Model: Polo TDi SL
Have this exact one currently. I'm a big fan of it. The touchscreen can be a bit irritating in the corners, especially when scrolling through albums.billionairebum wrote:Anybody seen or used this one?
https://www.autostyle.co.za/car-audio/d ... tooth.html
But the sound quality is good, the brightness works well, it has tons of customisable features.
I haven't used the Android function. This has to be connected via the rear hdmi input, so if you are going to do this, make provisions when installing. This should allow for the use of the mobile apps like JVC Control etc.
The Bluetooth playback is good, call clarity good and volume is hundreds.
My biggest issue with it is that you require a cage almost to fit in the double done gap in the polo, to make it fit snug. Got the cage from autostyle, but because it's such a tight fit, it pushes down on the top of the cd slot, which isn't ideal.
The colour scheme looks good in the polo also.
Hope this helps! Shout if you need any help.
Sent from my F5121 using Tapatalk
Current: 1.9TDi SL | GTB17 , 7+7 billet | PD-Tuning Stage 3 - 180wkw, 512nm | FMIC, 57mm Straight Pipe | 'Akrapovic' tailpipes | JVC-KWV | FK coilovers | OZ Ultraleggera Reps | Vari Slotted Discs & EBC Green | K&N Cone Filter | HMS Custom Intake | When they ask what it cost, just say 'A bit'
Awesome thank you!
- Crawler
- Car Model: 9N3 Polo TDi
- Membership No: 1358
Look at this
The Kenwood KDCX5100BT sells for R2495
CW Polo TDi Sportline
Will check this out thanks man!Crawler wrote:Look at this
