Polo 9n3 interior lights
- morribiscuit
- Car Model: Polo TDi SL
If anyone can please help me!!
Decided to "upgrade" my interior by changing the vanity lights, reading lights and convenience lights to led ones.
At first the reading lights were shining brightly, but when I changed the convenience globe, it sparked near the connector and then all went dead.
Changed the fuse (#28) and the lights are now all working, except they are extremely dim.
Anyone experienced something similar? Brightness on auxiliary power or when car started is the same.
Car is a Polo TDi btw.
Please and thank you
Sent from my F5121 using Tapatalk
Current: 1.9TDi SL | GTB17 , 7+7 billet | PD-Tuning Stage 3 - 180wkw, 512nm | FMIC, 57mm Straight Pipe | 'Akrapovic' tailpipes | JVC-KWV | FK coilovers | OZ Ultraleggera Reps | Vari Slotted Discs & EBC Green | K&N Cone Filter | HMS Custom Intake | When they ask what it cost, just say 'A bit'
- vee4410
Re: Polo 9n3 interior lights
Possibly defective bulbs. Try changing back to original bulbs and see if that makes a difference.
2007 Polo 9n3 1.9 TDI
2004 Polo 9n 1.6
2015 MB w205 C180
2004 Polo 9n 1.6
2015 MB w205 C180
- Car Model: 9N3 Polo 1.9TDi
Try the bulbs directly on a 12V source and see if they are still as dim. Maybe they are just not very bright LEDs, not all LEDs are created equal....
I upgraded the interiors on my 9N3 TDI and they are super bright.
Used these in the front:
http://www.4x4direct.co.za/car-replacem ... -5630.html
and these in the back:
http://www.4x4direct.co.za/car-replacem ... -leds.html
With the front, the 2 x T10's were so bright I didn't bother replacing the festoon between them, just left the bulb out.
Didn't do the vanity ones under sun the visors, never use them.
whoops, just re-read your post and you mentioned that they were bright before the short. It's possible that some the the electronics in the bulbs were damaged in the short, but strange that they are now all dim. Try them direct on a 12V as I mentioned and also do as vee4410 says and try an original incandescent bulb to see if it's bright. Maybe also try get hold of a new LED bulb of the same type that you got originally and see if it is brighter than the others. If it is bright, sounds like the bulbs may have got damaged.
- morribiscuit
That's the strangest part, I bought a good few so I had spares and they are all the same brightness!rob_hey wrote:whoops, just re-read your post and you mentioned that they were bright before the short. It's possible that some the the electronics in the bulbs were damaged in the short, but strange that they are now all dim. Try them direct on a 12V as I mentioned and also do as vee4410 says and try an original incandescent bulb to see if it's bright. Maybe also try get hold of a new LED bulb of the same type that you got originally and see if it is brighter than the others. If it is bright, sounds like the bulbs may have got damaged.
Except the ones for my number plate which are super bright!
When I put the standard bulb back in it doesn't light up at all.
It's as if there isn't enough power getting to it? As un-electrical as that sounds. Any idea if they're all in series or parallel?
As originally mentioned, the led ones initially worked brilliantly, but as I put the festoon in and it sparked, it's gone downhill since.
- morribiscuit
They are working 100 %. And very bright! The ones in my number plate are magic, but inside its as if they're on 10% brightness.rob_hey wrote:Try the bulbs directly on a 12V source and see if they are still as dim. Maybe they are just not very bright LEDs, not all LEDs are created equal....
Hmmm, that is strange. I don't see how the wiring or tracks in the roof light would be affected by the short. The fuse would have (and did) popped quickly so as to save to wiring. Maybe someone on the forum with more electrical knowledge could shed some light? Have you tried one of the "dim" LEDs direct on at 12v source (car battery)? Are they dim or bright?
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
You could have blown the dimmer unit. Hence its running lowest output , happens every once in a while.
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
Ahhh, good point. Forgot that they dim as they shut down. Not sure where this unit is located or if it's replaceable?
- morribiscuit
I think that sounds extremely likely!
- morribiscuit
Any idea where this dimmer unit is located?Kavi4GP wrote:You could have blown the dimmer unit. Hence its running lowest output , happens every once in a while.
- Car Make: Toyota
Think its in the front light unit.morribiscuit wrote:Any idea where this dimmer unit is located?Kavi4GP wrote:You could have blown the dimmer unit. Hence its running lowest output , happens every once in a while.
2006 Toyota RunX
2006 Toyota RunX
- morribiscuit
So an update, still looking for the dimming unit
