Polo 6R - Bluetooth Module RCD210
- Car Model: MK5 1.9 TDI DSG
Hi Everyone,
I have a 2011 Polo 1.4 Comfortline with the RCD210 factory radio.
I would like to install the OEM Bluetooth module to allow calls via the headunit and steering wheel controls.
Any idea where one can get this module and have it installed? (VW quoted R4200)
Thanks!
Thanks!
- Belix
- Car Model: Passat B8
Re: Polo 6R - Bluetooth Module RCD210
I'd try senna and Taffy on the forum, otherwise I got mine, and some other stuff from carsystems.pl
- Car Make: Toyota
- Car Model: GT86
Hey - I was looking to do the EXACT same thing a while back.jimbo wrote:Hi Everyone,
Thanks!
Very very long story short here is what I ended up doing. (I have a polo C/L 2010 6R)
The bluetooth module will work with the RCD 210 - but you will* be able to stream music, it wont work with your steering wheel, it wont integrate with your cluster, you will need the microphone too - so essentially you are paying R4200 for a glorified bluetooth speaker.
I am currently in the process of taking out the RCD 210 in place for a RCD 510 - this way I can get bluetooth (should I want to fork out the R4200 for the module and microphone), but I WILL get SD card functionality, 6 CD stacking player, touch screen, USB (at a very small added cost - if you want it done right - you will need to get the socket if you dont want a dangling cable, and the wire harness for the socket), Aux, and all of it will work with the steering wheel, just not the cluster.
My suggestion to you - remove the RCD 210 as I have, and replace it with an RCS 315 or RCD 410 and above.
I will be making a DIY tutorial on how to swap the RCD 210 in the future.
PM me if you need more info.
2008 1.4 Citi Chico (Carb) - 2013 - 2013 (Stolen)
2008 1.4i CitiSport - 2013 - 2015 (Sold)
2010 1.6i Polo 6R Comfortline - 2015 - 2019 (Sold)
2015 2.0 Toyota GT86 High 2019 -
Hi,Deago999 wrote:Hey - I was looking to do the EXACT same thing a while back.jimbo wrote:Hi Everyone,
Thanks!
Thanks for the advice, I was beginning to wonder if the Bluetooth module was worth all the effort (and money)
I think the more worthwhile route is to go with the RCD510 once I have the available funds...
Will be looking out for your video in the future!
Sent from my LG-H815 using Tapatalk
- rodga
- Nazi Spelling Master
- Car Model: MKVI GTI
- Membership No: 1323
Check out the 315
rodga's ride
'09 Generic XOR 125 - matte black - Daily Driver
rodga's ride
- Car Model: 6R Polo 1.6 Comfortline
I'm in the same boat currently. Sitting with the 210, aux cable in the phone.
I actually don't mind it too much, as Waze alerts also comes through there, but i would like the option of USB/SD.
- jetta786
- Car Model: MK5 JETTA COMFORTLINE 2LTR
- Membership No: 1715
Hi Belix,
did you manage to make the video clip removing the RCD210 TO WHAT YOU CURRENTLY HAVE?
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
RCD360 is a better upgrade with Android Auto and Aplle Car Play built injimbo wrote: ↑Sun Apr 02, 2017 6:41 pm Hi Everyone,
Thanks!
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
- Belix
I did not think of it at the time, it was pretty straight forward on my Mk6, used a trim tool to remove the radio surround, four torx screws and it slides out. drop the lever on the quad lock connector on the back, and clip for antennae plug. Swap radio and redo everything. New radio asked for code on first boot. I started with an RCD310 so it was the same size.
Think it's slightly more complicated on a mk5 but not by much.
- Registered for: 1 year 8 months
- Car Model: MK6 Golf, MK5 Jetta
