Cutting citi door card bigger for speaker? + Baffles + more
- TemoMK1
- Car Model: Velociti 1.4i
Hi guys,
Few questions about the golfies front door speakers.
1. Going to 6.5 inch speakers. Must you cut the door card's hole bigger? Or will the standard size hole "block" some of the new speakers sound.
2. Speaker fitted to the door or the panel? Mounting depth is only 4.3 cm so spacers aren't needed.
3. Foam baffles behind the speaker in the door. Do they work or is it a waste?
4. Finally, is it worth fitting deadning if its only going to be on the front doors?
If anyone has any pics of a Citi golf door with deadning, could you please post it. As im not exactly sure where to stick it...
Thanks in advance
Thanks in advance
Velociti 1.4i
Re: Cutting citi door card bigger for speaker? + Baffles + m
Will be interesting to see what is the suggestion, my drivers side speaker keeps falling from the standard setup, i have even removed it.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
In a Citi you are much better mounting the speaker to the metal door frame with some mdf rings. You should also look at blocking off the holes in the door frame with some wood or perspex and a layer of deadener. This will make a huge difference to your midbass output.
I will try and find a thread or some pics
Thanks KW, pictures will be appreciated.
- 1 Eyed Monkey
- Membership No: 1280
TemoMK1 wrote:Hi guys,
HELL YEAH!!!
Thanks in advance
SHAUN wrote:Only been watching midget porn lately, uses half the data.1 Eyed Monkey wrote: If you know Shaun, you'll know he has the biggest porn collection in Gauteng....
I used mdf spacer rings for the speakers when I had my 6.5inch speakers fitted in my citi. Deadening will help a lot!
Hookit532
Hookit532
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Unfortunately, I cannot find mk1 pics.
But google mdf speaker spacer for an idea. Then just block off the 2 big gaps in the door skin to create an enclosure for the midbass
Awe! KW, will do, i saw on some other thread that u will be opening a workshop in Crown Mines, how far are u with that?
Will u be doing audio stuff as well?
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Howsit bud.
Things are almost sorted. We should be running in the next week or two.
Sound isn't core business but we are always willing to assist where we can.
All the best KW, let me see if i can source the spacers, will let u know if i fail.
- 1 Eyed Monkey
Killerwatt wrote:Howsit bud.
