RCD 310 Bluetooth
- Car Model: Touran 2.0tdi
RCD 310 Bluetooth
Can anybody please tell me where the bluetooth unit for this radio is situated in the 2011 VW Touran? As far as I can make out on overseas forums, it is supposed to be under the seat, but the Touran has got drawers there! Or is it underneath the drawers?
- Belix
- Car Model: Passat B8
Re: RCD 310 Bluetooth
If it follows G6, its on the floor on the drivers side. So chair all the way back. depending on bluetooth version, it's either under a small carpet flap, or just loose in a styrofoam protector.
Online
- rodga
- Nazi Spelling Master
- Car Model: MKVI GTI
- Membership No: 1323
That's if the car was specced with bluetooth...
Sent from my SM-N900 using Tapatalk
rodga's ride
'09 Generic XOR 125 - matte black - Daily Driver
rodga's ride
Thanks for your responses so far. I can activate the bluetooth audio on the radio and have all the buttons on the steering wheel, but my cellphone does not connect to the radio. I have seen on overseas forums that you need to reset the bluetooth unit if this happens, now I need to find the unit. Alternatively, how can I determine if the vehicle was specced with bluetooth?
Online
- rodga
All rcd 310 have the bt option on the radio, so do all mk6 have the buttons on the wheel even if the actual bt module isn't installed. It is probably the same for the tiguan. It was a R2500 option for the mk6.
rodga's ride
rodga's ride
OK, thanks. Second question - how do I find out if the car was specced with bluetooth? And, of course, if it wasn't, how difficult (and expensive) is it to fit OEM bluetooth?
- Belix
If you can find a parts guy with a bit of patience, you can give him your VIN. ETKA greys out parts not fitted to your car, so if you find the page with the bluetooth module on it, if it's greyed out, it was not fitted. a VCDS scan will show currently installed modules, but not necessarily what was originally installed.
If you get a retorfit kit from kufatec or carsystems, it should come with a plug and play cable which makes fitting it pretty easy, although you'll liekly have to stash the module in the dash somewhere.
Also check with Tuffy on this forum as he seems to have a shop along similar lines to carsystems and Kufatec, but in RSA, which makes life a lot easier as he can do the install too.
Thanks, will see what I can do with the parts guys. Have also sent Tuffy a pm.
- Car Model: Mk2 Gti 8v
Hi, so what was the resolution to your Bluetooth issue with the RCD 310 radio ?
BMW E30 325i
Jetta 6 1.4 TSI
Ex-MK2 Gti 1988 1800, 8v OEM
Ex-MK1 Gti 1985 , CTI injection.
Ex-MK3 Vr6 97exec(standard).
Ex-VFR 400(NC30) 1992, aftermarket Can.
Ex-MK1 2door- 1800 8v, 4-1 branch,powerflow 50mm(RIP)
Ex-1990 Mk2 CSL Jetta aka VR1(Sold)
Ex-1987 Toyota Corolla 1.6GL slantfront(stolen)
Rides thread : http://www.vwclub.co.za/forum/viewtopic ... 4#p2505684
Jetta 6 1.4 TSI
