ECS Cam Chain Tensioner Service Kit
Registered for: 19 years 2 months
I have a few of these kits in stock.
Parts you need to service the cam chain tensioner on your 2.0T FSI
Priced at R2150
It is common for the tensioner to fail and cause the timing chain to break. You can use this kit as preventive maintenance or to repair a chain failure.
Kit includes:
Timing chain housing gasket
Timing chain
Timing chain tensioner
Timing chain tensioner hardware
Camshaft adjuster bolt
PCV valve gasket
Valve cover gasket
Camshaft follower for high pressure fuel pump
High pressure fuel pump hardware
O-ring for camshaft adjuster solenoid
