My Mk5 GTI - Sold :(
G-spot
Car Model: 6c Cross polo
Membership No: 1215
Postby G-spot » Tue Dec 09, 2014 10:27 pm
So some may know, after a loooong wait, I recently took ownership of Chicken Licken's old GTI. CL sold the car and the previous owner had the car for a total of 13 months, And done roughly 4000km.
The car is in a exceptional condition all round considering its almost 8 years old
The full rides thread can be found here : viewtopic.php?f=11&t=40723
The car has been meticulously looked after, with only the OEM or the best parts used.
(taken from his rides thread)
Factory Trimming include:
Xenons
PDC
MFS
Ipod Prep
Sat Nav / DVD player (MFD2)
Sunroof
Exterior
Votex front spoiler in matt UG finish
Front Grill in matt UG finish with Imola Yellow Lip
Imola Yellow brake callipers all round
Front and back VW badges in Matt Tungsten Pluto finish
GTI - Debadged Front and Back
Full Colour Coding all round (Semi-rear OEM bumper)
Finished Side Mirrors in Matt Tungsten Pluto
Rolled Arches front and rear to accommodate Suspension
.:R20 MK V Rear LED Lights in red/smoke
Tinted (Tint) Lens covers on front OEM Xenons - Maldino Customs
5000k HID Fog Lamps (Rear Projection ESC Fogs) - with TINT Lamix
Rear Window Winder Delete
Rear Hatch Pop Kit with Key activation
Moddified engine cover to accomodate CAI piping
Interior
DEFI Racer Blue boost gauge (PSI) with OSIR Pod
OEM VW Blue tooth integrated with MDF2 SAT-NAV
14 piece Full interior LED package
New GTI Leather steering wheel
OSIR dead rest pedal
Polar FIS+ Advanced (PF03) HUD Telemetry
Wheels and Suspension
VMR V710 8.5j ET45 19" Rims in Chrome Black
Imola Yellow Customer "VMR" detailing on the Centre Caps
225/35/19 yokohama S-drives
KONI Sport Dynamic Shocks and H&R Sport Springs
H&R 5mm spacers in the rear
2 aluminium spigots for the rear wheels to accommodate 5mm spacers
Green .:R32 low pressure indicator valves for all 4 wheels
Performance Upgrades
Neuspeed Intake in PFlow with CAI pipe
Neuspeed 6180 Light Alu pulley and belt
Neuspeed (Garrett Core) 14 row FMIC
Autotech high pressure fuelpump upgrade
REVO 2+ software
REVO SPS device
Experience 76mm DP
EBC GD 312mm Brakes with Yellow Stuff Pads
70mm powerkoted rear twin tailpipes
x4 NGK bcpr8eix colder spark plugs
ECS pcv blockoff
So since I had the car there has been a few issues I had to attend to as well as changes I made
The first was a few of the LED's were on their way out, So replaced them with new ElectromannSA LED's
Second was the performance, The car is seriously lacking go, At first I thought it was a boost leak, Which we found was where the silicone hose clamps over the FMIC, The cooler has oval ends, So was leaking out the long end. We took off all the piping, cleaned everything and put it back.
At the same time Martin (Scatman) removed the Neuspeed air filter extension (relocates the filter to behind the fog light) Which helps massively for air temps, However there is no opening for direct air to flow to the filter, Usually DSG grills would sort that out but with the FMIC piping the DSG grills, Well the ducting for it, doesn't fit. That and my fear of hydrolock, moving the filter back up was a logical decision .
While busy under the car I also installed a GFB DV+ along with the RevH OEM DV.
So after everything was put together, I was rather disappointed as the car is still under performing. After speaking to a few guys, including CL, It was concluded that the boost is being held back due to agro timing, Which is meant for high octane fuel. With this being my daily, Running OB in every tank is unrealistic, So sw will have to change. The current revo 2+ map has been on the car for a while, so im sure just a revised map will work wonders for the car.
With that done, I arranged with Morne (g60) to do a Oil change service and give the car a good look over. Oil was changed as well as plugs (NGK PFR7G, Laser Platinum)
He did pick up a fueling issue, which has made me massively paranoid, But from what I've read, The lpfp should run around 6/7 bar, Mine runs around 3.7/4 bar, and dropping to as low as 1.1/1.3 when hoofing it :eek: . so this could either be a blocked filter, or a failing fuel pump, Either way, both on the to do list to change. VW wants R4200 for the pump and GW delarey can only supply OE parts, which suits me, And luckily its 2/3s of VW's price. They on back order so waiting for stock then back to Morne to fit. He also pointed out that the no1 and n04 coils have quite a bit of rust on them, So even though they are hassle free at the moment, I should maybe look at replacing them.
Ive also got myself a set of VW Roof bars (thanks Rodga), Which I already pulled apart and painted. I tried to get as close to the matt united grey as possible, And very pleased with the outcome.
So onto what my plans are... (for now, Im sure it will change as I go)
Happening in the coming week
Maintenance wise
-Replacing Fuel filter
-Replacing LPFP (should the above not sort the fuel pressure problem)
-R8 Coil packs
-New cam follower (just to be safe)
Mods wise
Revo - I'm really keen to get the Revo file off the car so that I can load my own file, Unfortunately revo protects the ECU. so cant load over it. I've arranged with Ian to have it flashed back to stock, however I would like to compare revo's 2+ to our map. Ian said he will happily load a revised file, and then remove it for me once dyno'd. so as soon as the fueling sorted ill be heading to Ian for that.
SW - Very keen to get my custom Wulfchiptegnik map loaded.
Turbo - Im working on getting a hybrid k03 turbo :grin: If that does not pan out ill look into a k04
Plumbing - based on the above, I'll be changing the Discharge and throttle pipes with a neuspeed ones (pending k03/4) But if I'm going K04, I'll get Nico at RC performance to do full custom piping.
TPMS - I want to install a OEM tire pressure monitoring system, Got the idea from Morne as done on his GTI. Very cool mod and OEM.
Boost gauge - I'll be removing the Defi boost gauge and Osir vent pod and re-installing the original air vent, I monitor boost on the FIS+, So no need for the gauge
Radio - I was planning on replacing the MDF2 with a RNS/RCD510, But having to spend money on a new fuel pump put that on hold. I'm leaning towards the RCD instead of the RNS, Purely because I have no use for the nav, and paying 3x more for a feature I dont really use is stupid imo.
PCV Blockoff - So Somewhere along the line the ECS PCV blockoff Sean installed was removed, and no one seems to know anything....But Morne said he will assist with blocking it off, If he cant, i'll just get a blockoff kit from Vagcafe
Cosmetics
R32 rear - Here im in 2 minds, I really like the R32 rear bumper, But The more I look into it the more i doubt my choice. So will see what happens over time.
Tail Lights - At first I wasnt keen on the .:R20 LED tails, But they have grown on me, I still don't like them on the day, But they look awesome at night. If I come across a set of OEM R32 tails i'll swop in a hear beat.
Yellow - The yellow is not working for me, So I'll be changing it back to the OEM red
Front bumper - So the front bumper is basically perfect Looks wise, But ive found that from all the taking off, painting and putting back on, the clips and guides have work and broken, So the bumper doesnt line up as well as it should. So between speaking to Morne and Aldo, As soon as this bumper is due for a respray, i'll be getting a new OEM bumper and having Aldo spray and fit it for me.
The guys that know CL, know he didn't take shortcuts with this car, I plan on keeping things that way as much as possible.
eventually I would like to revert back to the below look, Biggest change would be changing the wheels to United Gray
And a few of the latest pics:
That's pretty much it for now. I'm extremely happy with the car in general.
Grant Hendry
Membership no.:1215
2015 VW Cross Polo 1.2TSI
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
It will be built not bought, cheap not expensive, driven not hidden, abused and used and most of all I own it and I thrash it...
vdub caddy
Ian F's special snugglebunny
Car Model: Caddy
Membership No: 1548
Re: My Mk5 GTI
Postby vdub caddy » Tue Dec 09, 2014 11:27 pm
Congrats dude, wishing you many happy miles.
This was/ still is a favorite MKV of mine, and hoping you don't change too much. LOL.
As for the LPFP, I had mine fail as well and the car didn't hold boost nor did it have any go.
I have replaced mine with an OEM one from GW for the mean while until I can make up a bracket that will house aftermarket pumps in the stock basket.
Looks like you have some really good plans for the car, will be watching this thread closely.
Bullet03
Car Model: MK2
Membership No: 1821
Re: My Mk5 GTI
Postby Bullet03 » Tue Dec 09, 2014 11:28 pm
Congrats dude this car looks awesome
1990 Developments
BURNING RUBBER
Membership number : 1821
- 1989 CITI Golf akaPAMPOEN
*Ornament
- 1985 Mk2 16v
*Watch this space
- 2001 Opel Corsa GSI
- 2008 Honda CBR 125
- 2007 Yamaha R6
- 2008 Nissan champ
Uvy
Car Make: VW and Seat
Car Model: MK2 GTi 16V Golf
Membership No: 1740
Re: My Mk5 GTI
Postby Uvy » Wed Dec 10, 2014 7:33 am
Saw this at the breakfast run. damnnnnn shes sweet man.
Heaven on Earth - VAG for life
Uncle Nunda
Car Model: Scirocco R
Membership No: 1489
Re: My Mk5 GTI
Postby Uncle Nunda » Wed Dec 10, 2014 7:35 am
check the fuel pump not lpfp or hpfp
fuel pump it self
VW 'John Deere' TDI
Car Model: E90 LCI 320d M-Sport
Re: My Mk5 GTI
Postby VW 'John Deere' TDI » Wed Dec 10, 2014 7:56 am
Congrats on the new car. She's a beauty. :hurray:
Current: BMW 320d E90 LCi M-Sport - Yin & Yang
Ex: VW Polo 9n3 1.9TDI Sportline - John Deere
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, then please dear God protect my ride."
Car Make: Fiat
Car Model: Uno
Re: My Mk5 GTI
Postby Unobeat » Wed Dec 10, 2014 8:02 am
Congrats G-spot, this is a well taken care off MK5 and tastefully modded. :hurray: :hurray: :hi:
G-spot
Membership No: 1215
Re: My Mk5 GTI
Postby G-spot » Wed Dec 10, 2014 8:15 am
Thanks guys :grin:
Uncle Nunda wrote:check the fuel pump not lpfp or hpfp
fuel pump it self
Nando, Im talking about the low pressure one in the tank (lift pump), The HPFP is fine, I see Fuel rail pressure over 135bar regularly
Grant Hendry
Membership no.:1215
2007 VW Golf GTI
2012 VW Polo GTI
Re: My Mk5 GTI
Postby ruan9n » Wed Dec 10, 2014 8:41 am
A while after Dewald bought my 5 he also cried and cried about the LPFP, told him to replace the fuel filter but he persisted in getting a new lpfp- then before fitting that new lpfp he replaced the fuel filter and the car was 100s again! VW hardly ever replace fuel filters on these cars as they're "LONG LIFE" items.... you'll be surprised at the amount of black yoghurt sludge boktos that builds up in there starving the hpfp of 95.
Definitely get an R32 rear, just swipe you can wipe your tears away later!
hostility
↰ ↓ 4 ?
Car Model: Jetta 6
Membership No: 1624
Re: My Mk5 GTI
Postby hostility » Wed Dec 10, 2014 8:45 am
Congrats brother....epic car indeed....
francois_gti
Car Model: RS Mk5 Gti (Manual)
Membership No: 3041
Re: My Mk5 GTI
Postby francois_gti » Wed Dec 10, 2014 8:52 am
Beautiful car! I like all the planned mods. Many happy kms. :hurray:
Current: Mk5 Gti
Ex: Audi A3 1.8T
Ex: Citi Life 1.6i
Ex: Citi 1.6
Ex: Cti 1.8i
Tashveer
Car Model: Cti
Membership No: 2095
Re: My Mk5 GTI
Postby Tashveer » Wed Dec 10, 2014 8:54 am
Probably the best MK5 ever seen on this forum so congrats on a beaut there bud.
Personally I don't like the roof racks but that is your choice. Hopefully you get the performance stuff sorted soon.
Enjoy... :driving:
1993 CTi ABF
2004 Citi Life 1.6i
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Re: My Mk5 GTI
Postby VWicked » Wed Dec 10, 2014 11:25 am
congrats buddy, awesome ride that
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
Demon Tweaked
Car Make: VW & VW
Car Model: MK7R & MK6 GTI
Membership No: 1845
Re: My Mk5 GTI
Postby Demon Tweaked » Wed Dec 10, 2014 11:26 am
very nice! I will take those wheels off you when you ready. lol
LB MK7R 359WHP 511NM
MK6 GTI DSG UNITRONIC Stage2
AUDI RS3
BMW E92 M3 350WHP @ Rally Cross Motors
UNITRONIC SEAT Ibiza Cupra 1.8 20vT Stage3 434WHP 509NM @ KAR
VW Citi Chico 1.4
dbndude
Car Model: caddy
Membership No: 1147
Re: My Mk5 GTI
Postby dbndude » Wed Dec 10, 2014 11:29 am
awesome. i dig the yellow on UG.
G-spot
Membership No: 1215
Re: My Mk5 GTI
Postby G-spot » Wed Dec 10, 2014 12:14 pm
ruan9n wrote:A while after Dewald bought my 5 he also cried and cried about the LPFP, told him to replace the fuel filter but he persisted in getting a new lpfp- then before fitting that new lpfp he replaced the fuel filter and the car was 100s again! VW hardly ever replace fuel filters on these cars as they're "LONG LIFE" items.... you'll be surprised at the amount of black yoghurt sludge boktos that builds up in there starving the hpfp of 95.
So I have heard as well, That's why Ill replace the filter and see, If it is the pump, I might as well replace it while we are busy. if not, I'll return it for credit.
Lol, There is more important thing to to sort out and spend my money on at the moment, but will see, Maybe end next year.
Demon Tweaked wrote:very nice! I will take those wheels off you when you ready. lol
Get me a set of 19" Rotiform TMB's and you can have them :cool:
dbndude wrote:awesome. i dig the yellow on UG.
The yellow is a CL thing, just like the pink I had on my polo, It worked and looked nice, But it works for some, And not for others. The Yellow doesn't look bad, But its not me
The United Grey is awesome colour, it looks darker with dark accents like the wheels, And lighter with light accents, I preferred the darker look of the car
hostility wrote:Congrats brother....epic car indeed....
francois_gti wrote:Beautiful car! I like all the planned mods. Many happy kms. :hurray:
Tashveer wrote:Probably the best MK5 ever seen on this forum so congrats on a beaut there bud.
Enjoy... :driving:
VWicked wrote:congrats buddy, awesome ride that
Thanks gents
Grant Hendry
Membership no.:1215
2007 VW Golf GTI
2012 VW Polo GTI
Aslam_MK4
SO FLUFFY, WE ALL GONNA DIE!
Membership No: 1824
Re: My Mk5 GTI
Postby Aslam_MK4 » Wed Dec 10, 2014 12:43 pm
Awesome bud awesome
But why roof bars why
Bagged mk4 2dr
Tazo’s garage
Pm for all your air installs,sound,revo software,coilovers etc
"Ride or die
pyro-zn
Car Model: Golf 6 GTI K04
Membership No: 2072
Re: My Mk5 GTI
Postby pyro-zn » Wed Dec 10, 2014 1:15 pm
Congrats! :hurray:
Current: '12 TR Golf Vi GTi DSG ::: Revo3 - thread
Ex: '13 Polo 1.4 Comfortline ::: PanoRoof | JOM Bluelines | 17" A-Line Racers | 17" VW Boavista's
by Borbet - thread
DazzG_177
Car Make: SEAT
Car Model: Leon Cupra
Re: My Mk5 GTI
Postby DazzG_177 » Wed Dec 10, 2014 1:21 pm
Still my favorite MKV ever!
Congrats!
PoloRox
Car Model: 9n3 Comfortline ROX
Re: My Mk5 GTI
Postby PoloRox » Wed Dec 10, 2014 1:23 pm
very very nice car dude wishing you all the best
Ride Thread...
POLOROX...
FK Streetline COILOVERS
18" BBS LM REPS
HID 6000k HEAD+FOGS
Sony HU+ STARSOUND AMP+ PIONEER SUB
GLOSS BLACK CUPRA LIP.
Ex: VW CitiRox _Reflex Silver
Amith11
Car Make: DUH !!!
Car Model: MK7 GTI
Membership No: 1545
Re: My Mk5 GTI
Postby Amith11 » Wed Dec 10, 2014 2:22 pm
Best G5 in my humble view.
I still have a pic of this car on my company phone as a wall paper.
Nice ride Mr G.
Spotted you on Hendrik Potgiter this morning. I hooted but you no see me.
MK 7 GTi
Lost Loves:
MK4 TDi
Mk4 GTI .:R (True Love)
MK3 Cabriolette 2.0l Exec
Mk2 GTI 1.8 8V
Mk1 GTS (4door)
Stompie
Boostleak Guru
Car Make: VW POLO
Car Model: 07' GTI 9n3
Membership No: 1843
Re: My Mk5 GTI
Postby Stompie » Wed Dec 10, 2014 2:40 pm
This must be one of the hottest MK5 GTIs in my book!!
Congrats on the car dude!
07' Polo GTI 1.8T Rides Thread Here
cli 16v
Car Model: Audi A4 1.8T
Re: My Mk5 GTI
Postby cli 16v » Wed Dec 10, 2014 3:36 pm
Congrats buddy, always loved this car. Oh and btw the OEM .:R32 tails that were on this car are now on mine :lol:
'15 MKVII GTi
'07 MKV GTi OEM+
'89 MKII Golf CSL OEM
'97 MKIII GTi Exec
AlexTDi
Car Model: '15 Polo GTI
Membership No: 1724
Re: My Mk5 GTI
Postby AlexTDi » Wed Dec 10, 2014 3:43 pm
Should I ask Gazza to call you for pointers on where to get Air?
Alex
VWCSA Member No. 1724
AT Photography
Daily: '15 6C Polo GTI DSG
Race Car: Polo Vivo GT
Tow car: '06 Land Rover Freelander TD4 HSE
Daily: '06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
MeanTdi
The Imposer Mod-whore-rator
Car Model: Polo 1.9 TDI Sportline
Membership No: 1153
Re: My Mk5 GTI
Postby MeanTdi » Wed Dec 10, 2014 4:05 pm
Congrats bud! Stunning ride :drool:
Marco
Ride: VW Polo 1.9 TDI Sportline
Users browsing this forum: Bing [Bot] and 35 guests
