KIWI with a POLO
- PiRACY
- Car Model: Polo 9N3 GTI
KIWI with a POLO
Hi,
I guess firstly I should just say I very much appreciate the effort it must take in maintaining this forum.
It has been a very valuable source of information and insight whilst researching my car.
My recently acquired car is a VW Polo 9N3 GTI (2006) 2 Door (Coupe), Ex-JAPAN. Arrived with 36,000kms. It is completely immaculate inside and out, and arrived 100% unmodified. Here is my log of everything done so far:
APR Stage 2+ ECU Flashed
Replaced Engine Oil with Liqui Moly Top-Tec 4200 5W-30 (Twice to really flush the Castrol out)
Changed oil filter with Genuine VW filter + sump plug
Changed Fuel filter with Genuine VW Replacement
Flushed Coolant system with 20L plain De-ionized water, then double flushed with Genuine G13 50/50 De-ionized water mix.
Replaced all Power Coils (Genuine VW Part No. 06A 905 115 D)
Replaced Dogbone Mount with Genuine OEM Replacement
Refreshed Manual Transmission Fluid with OEM (2 Liters)
Replaced Plugs with Denso Iridium TT (Twin Tip) IK20TT @ Factory Gap)
Installed Bosch 4.0 bar Fuel Pressure Regulator (Part No. 078 133 534 C)
Installed Forge Turbo Intake Pipe [Black] (Part No. FMINDIBFR4)
Installed Forge Piston Recirculating Dump Valve [Black] (Part No. FMDV008-B) + Installed included Yellow Spring (15-23 PSI)
Replaced PCV 'Puck' Valve (Part No. 034 129 101 B)
Replaced Check Valve (Part No. 058 905 291 B)
Pipercross Panel Filter (Part No. PP1599)
Replaced MAF Sensor with Original Bosch (Part No. 0280218063)
Installed PD160 SEAT SPORT Cold Air Intake Pipe/Trumpet (Part Numbers: 6LL 129 + 621 6LL 129 618)
Installed Airtec SEAT SPORT Style Front Mounted Intercooler (Black)
Replaced Intercooler MAP Sensor with Bosch (Part No. 0281002399)
Installed Forge Intercooler to Throttle Body Hose [Black] (Part No. FMPOLOTB)
Installed Newsouth Turbo Boost Gauge + SWG Motorsport 9N3 Vent Pod
Installed Milltek Full Turboback system (Front to back) Including High-Flow Sports CAT
Replaced all four Wheel hubs and bearings [Febi Bilstein 24414 FRONT]+ [Febi Bilstein 24224 REAR]
Replaced L/R Front Control arms + Rear-Front Bushes & Ball Joints
Installed Ibiza Cupra Uprated Console Bushes 6LL 407 183 (FRONT)
Installed Cobra Performance 'CP' Racetech'/HEL Front & Rear Braided Brake lines (VW-4-282)
Installed Brembo MAX Front Discs (Slotted) (09.7010.76)
Installed Brembo MAX Rear Discs (Slotted) (08.7165.75)
Installed Brembo Front Pads w/ Indicators (P85077)
Installed Brembo Rear Pads w/ Indicators (P85066)
Various other items replaced such as stainless hose clamps, Bosch Wiper blades, Cup Edition Stubby-Whip Antenna etc etc...
Now looking into Water-Meth injection, suspension, and mags.
- AshG
- Car Make: Ford
- Car Model: Fiesta ST
Re: KIWI with a POLO
Welcome! Sounds excellent. Please share more info and pics in the "Rides" section.
Current: 2017 Ford Fiesta ST
2009 VW Tenaciti 1.4i
2013 VW Polo Vivo GT(Zorst)
2007 Ford Focus 225 ST(stock)
2010 VW Citi MK1(No. 512){Primaforce branch+zorst}
- NHB_R
Where's the pics
- PiRACY
I'll post some when the car is bit more presentable. Researching paint correction and new headlights. The original headlights are very hazy and completely ruin the overall appearance. Probably going to get the black Xino DRL headlights. Exhaust system should arrive this week. Also contacted APR and confirmed that I'm eligible for a FREE upgrade to Stage IINHB_R wrote:Where's the pics
- Pynoxim
Very nice man, I've got a friend with a Japanese Polo GTI as well, his came with a very strange set of options, like a radio blank off plate and a tyre pressure monitoring system.
- PiRACY
It actually does have the pressure monitor. I thought that was a standard feature. Haven't even used it yet.Pynoxim wrote:Very nice man, I've got a friend with a Japanese Polo GTI as well, his came with a very strange set of options, like a radio blank off plate and a tyre pressure monitoring system.
- Sebz
- Car Make: BMW
- Car Model: 135i E82 N54 ST 6MT
- Membership No: 3020
Hello and welcome to the VW Club Forum!
We all hope that you enjoy your stay here and consider the wonderful opportunity of becoming a VWCSA Member and get awesome vwclub merchandise for only R300.
Before you do, please have a look at the Forum Rules
As well as the rules we have for Private Sales
If you have any questions pertaining to your vehicle and not to do with introducing yourself, post them in the Technical Discussions section
Please feel free to join in on the Events, its huge fun, and non-members are also more than welcome to join in on the action. Hope to see you at an event soon.
Now that you have introduced yourself to the forum, have a look at starting a Rides Thread and show us what you cruise the streets with.
(How to Post a Picture)
We look forward to having you on the forum, and hope to see you grow in the club, by becoming a member, and most of all, making new friends.
Cheers
Cheers
Single turbo BMW 135i N54 6MT
Ex's:
Brilliant BMW 135i E82 N55 6MT
Stupidly static THANAS Tuned '05 Audi A4 B7 2.0T FSi
Definitely down-to-earth '03 Audi A3 8L 1.8T
Ludicrously lowered K04 '03 Audi A4 Avant B6 1.8T
Sorta slammed '15 VW Polo Vivo GT 1.6
Stock standard '05 Opel Corsa D Ute 1.4
Ridiculously reliable '81 VW Passat CSL Estate 2.2 5-pot
It's not how you stand by your car; it's how you scrape your car. You better learn that.
Ex's:
- PiRACY
Finally the Milltek Full system arrived, and was just installed and the ECU updated from APR Stage 1 to APR Stage 2+ ... Initial thoughts: Get new discs, pads, control arm bushes etc ASAP!
- Pynoxim
Are you going for replacement rubber or polyurethane? Just be aware that if you do go for the poly option, doing the dogbone in poly will result in excess vibration at idle and pull off, it isn't super bad but it's noticeable and you get used to it.
- PiRACY
Hi, I'm probably going with Superpro Purple/Blue (not black) Poly Lower-Inner Rear & Lower-Inner Front Control arm Bush Kits; only for the control arms. The dogbone/torque arm bush I've actually already replaced with a new OEM one because I could easily see that the rubber was perishing. Replacing it definitely tightened up the gearbox movement to acceptable standards. I'm very interested in the Vibra-technics engine and gearbox mounts, but I dread to think about the work involved.Pynoxim wrote:Are you going for replacement rubber or polyurethane? Just be aware that if you do go for the poly option, doing the dogbone in poly will result in excess vibration at idle and pull off, it isn't super bad but it's noticeable and you get used to it.
- PiRACY
Ordered the Uprated Cupra Solid Bushes and new control arms (which include new front bushes and ball joints).
- Reegz
- Membership No: 1400
Welcome to the forum!
2016 Golf 7 Tyre Devourer
---- Ex ----
2008 Honda CBR 600RR - SOLD
1996 Citi Golf CTi - SOLD
---- Ex ----
- Neuk
- Treasurer
- Membership No: 806
Welcome and enjoy the forum
Sent from my iPhone 7 using Tapatalk Pro
