Morning everyone, I'm new to the group my name is Nyambose, I drive a 2006 Polo 9N facelift, this morning when I tried to unlock the car it didn't unlock so I opened it manually using the key but the other doors won't open manually even from the inside, so the car doesn't lock or unlock centrally the remote works
Please help I'm stressed.
Central locking problems
- Car Make: Me.. Fortuner...Vrou...Polo
- Car Model: 2.5...... Can't Afford a 3.0
Re: Central locking problems
Check the fuse for central locking . Fuses are located on the driverside of dashboard . Use a flat screwdriver to pry open the cover . Fuse card in there will show you which fuse to look for .
Hope it helps
Hope it helps
